Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-06-2013, 06:09 AM
HIH1 HIH1 is offline
Caprice 1986 Borougham high idling
Hello
When start my Caprice (1986) carb-- I used to step on the gas pedal (half step is more than enough) to start the car.
Once the car started it's idling normaly, but suddenly after 3 or 4 minute the sound of engine go high idling as if I steped on the gas and that is remaining for long time even if I step full gas, and if I turnoff the the engine and pull out the key, the car will remain working hardly and shaking like crazy befor it compeletly stop.
What is the problem with my 86 Caprice Brougham? is that problem easy to fix?
Thank you very much
Old 12-06-2013, 07:31 PM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
Re: Caprice 1986 Borougham high idling
I think you problem revolves around the carb. Its either choke related, or throttle is sticking, maybe butterfly inside the carb is sticking. Its def carb related.
"He who makes a beast out of himself gets rid of the pain of being a man."---Dr Samuel Johnson
Old 12-08-2013, 02:14 PM
j cAT j cAT is offline
Originally Posted by HIH1 View Post
Hello
Thank you very much
with the carb you have vacuum operated choke pull off components. when these leak the choke pull off arm does not retract quickly then you get a 1700 rpm idle until the choke stove gets hot.
check that these devices pull in fast when vacuum is applied.
do not use any carb cleaner on these this is how the rubber gets destroyed .
