Old 12-04-2013, 03:06 PM
goblinz goblinz is offline
1995 chevy lumina dies when stopping and reversing?
My brother's 1995 chevy lumina 3.1 engine has been dying while braking for a stop and while reversing. Has replaced fuel filter, map sensor, throttle sensor, o2 sensors and still no change. He says he doesn't believe a tune-up is the cause either.
Any ideas?
Old 12-04-2013, 05:38 PM
aleekat aleekat is offline
Re: 1995 chevy lumina dies when stopping and reversing?
Put it in neutral or park running. Step on the brakes. If you see rpms fluctuating, suspect brake booster check valve. Relatively cheap.
Post back, that's what makes Forums Work.
Old 12-04-2013, 07:16 PM
maxwedge maxwedge is offline
A990 racer
Does it start right back up, are there any other performance issues?
Old 12-05-2013, 04:46 PM
he tried that method but there was no change in rpm.....the car starts up fine even after dying but he said that sometimes it acts as if it doesn't want to start....i remember a few weeks back when he put the car in reverse gear it would die on him unless he would give it some gas (sometimes it still would die)
yesterday he tried disconnecting the brake booster and using the brakes to see if it would stall but the brakes just became hard
Old 12-05-2013, 06:50 PM
A990 racer
If you have an egr valve disconnect the plug see what happens, also clean the throttle body and remove the iac and clean that also.
Old 12-05-2013, 07:06 PM
Schurkey Schurkey is offline
I'd have said "test the IAC"; with cleaning recommended if the thing works at all.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 12-05-2013, 08:07 PM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
I would suspect IAC aswell. Maybe Battery connections? Ive also heard on older cars that 3.1l that is, that the computer wiring will begin to come lose at the ecm. Just a couple of ideas thrown out there. IAC couldnt be more than what 30 bux or less? Pull one from a scrap yard haha, and clean it.
"He who makes a beast out of himself gets rid of the pain of being a man."---Dr Samuel Johnson
Old 12-05-2013, 08:12 PM
Plus the thing HAS to have a check engine light on. What are the codes? Could be crank shaft POS sensor, if that doesnt work it will die. There might be two of them aswell. Another idea.
Old 12-06-2013, 10:02 AM
Tech II Tech II is offline
I agree with Max......try cleaning the throttle plate edges, and the mating bore in the throttle body, remove the IAC and clean the pintle and the surface of the mating passageway.....check the connection in the harness for the IAC for loose connectors(drag test with a male connector).....
Has the car been scanned for codes?
