Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-04-2013, 09:36 AM
HIH1 HIH1 is offline
Caprice 1986 Tranny and carb
Hello guys
I'd like to know if the Transmission of Caprice 86 has some electrical connection (for control), can disconnect it and still use the car?
Dose it has an electrical carburetor? if yes can I dissconnect it and still can use the car with out any problem?
Which caprice you would recommend 86 or 79?
Thank you.
Old 12-04-2013, 06:59 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Caprice 1986 Tranny and carb
Originally Posted by HIH1 View Post
Hello guys
86
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 12-05-2013, 12:20 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Hello guys
Thank you.
You can disconnect the electrical connection to the transmission (this controls the torque converter clutch or TCC), however, don't expect the transmission to live long with this TCC line disconnected - especially if you live in a hot climate. Also, your fuel economy will suffer with it disconnected.
You may also disconnect the electric lines to the carburetor (both M/C solenoid and TPS), but don't expect to get more than 5MPG, or have enough power to take pleasure in driving.
Now, having said that, why would you want to disconnect either one? The computer system that runs both actually contributes to better driveability on the car, and better fuel economy. It's not recommended to remove either one.
The 1986 is a better car than the 1979, due to improvements over the years.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-05-2013, 03:03 PM
Very helpful ..thank you alot Sir
