Go Back   Automotive Forums Car Chat > Kia > Sedona | Carnival II
Old 12-01-2013, 08:17 PM
famlycar famlycar is offline
09 kia sedona drain plug location?
Does anyone know where that drain plug is for the radiator? I see something under there that is a white plastic nut that has a phillips head on it. I want to drain the coolant and then add more that is clean. also, do I have to turn on the engine when draining and re-filling?
thanks
Old 12-04-2013, 06:05 PM
rhandwor rhandwor is offline
Re: 09 kia sedona drain plug location?
thanks
Go to http://www.ebay.com type in your Kia Sedona radiator drain plug. They sell them and have a diagram of where it is located on the bottom of the radiator.
I wouldn't run the engine with the system drained. If you want to flush it pull the bottom hose and a radiator hose and flush until clean.
Old 12-05-2013, 06:48 PM
Ok. I checked ebay but it doesnt really show where it goes in the diagram. So I think maybe its on the side. I'll check.
Also, how often should a radiator be changed or flushed? and how do I know what condition the radiator is in? what is the average life of a radiator?
thanks.
Old 12-05-2013, 07:32 PM
thanks.
The diagram says item 7 bottom left side facing the radiator. The life depends on the antifreeze and and how frequently it is changed. When the car is overheating is the time to change it anti freeze lasts longer than it used to I think you should have 10 or more years left.
Old 12-05-2013, 09:25 PM
OK thanks. I went to the 2nd page and got a better diagram of its location. So, it is that plastic thing on the bottom with a phillips head on it that I originally thought. Thats really a strange looking drain cock. I don't know how Im going to loosen that without getting coolant all over my hand.
Old 12-06-2013, 07:52 AM
Were rubber gloves.
