Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-30-2013, 12:24 PM
jtmarten jtmarten is offline
O2 Operating Range
What is the normal operating range reported on a scan tool of upstream O2 sensors for a '96 K2500 w/7.4, also for fuel trims?
Thanks!
2005 Saab 93 Aero
1996 GMC K2500 Sub w/conversion pkg
1964 Ford Falcon 'vert
1980 Bradley GT2 96v Electric
1978 GMC Royale Motorhome
1978 Glastron/Carlson CV23; 460/Berk JE jet
Old 11-30-2013, 06:47 PM
777stickman 777stickman is offline
Re: O2 Operating Range
http://alldatadiy.com/buy/
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-01-2013, 11:30 AM
Tech II Tech II is offline
Normally large swings from 900mv to 100 mv.....
Fuel trims usually less than 10%, plus or minus....zero % would be a perfect running vehicle, so it will vary slightly above and then slightly below zero....
OBD I, didn't use a %, they used 128 as a base line, and readings would vary slightly above and below the 128....
Old 12-06-2013, 05:33 AM
Thanks for the info. Was curious about it because I have one upstream O2 showing ~0.850 and the other showing ~0.08 at idle. I've been getting a bank lean code lately. I'm planning on replacing both upstream sensors.
2005 Saab 93 Aero
Old 12-06-2013, 07:16 AM
j cAT j cAT is offline
what you do when the readings are different is swap them . if the problem swaps it is the sensor if it is the same side you got engine problems.
could be vacuum leak.
