Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-26-2013, 01:25 PM
TriumphTigerCub TriumphTigerCub is offline
Fuel Pressure Regulator -Ruptured Diaphram
Members
I have a 2001 Jimmy 125,000 miles - Replaced original Fuel pump, Spider ,and fuel filter. After 3 months of running great , the Fuel Pressure Regulator failed . Installed new one and it lasted about three days. Now I'm going on the fourth one . They only last a few days then the diaphragm ruptures.
Has anyone had this trouble ? If so what was a solution ?
UP DATE : I just installed another new FPR I hooked up the lines and checked the pressure to see if the new one leaked. Everything looked OK . I relieved the pressure at the test gage . When I removed the fuel lines to begin putting the plenum on a little gas ran out of the large fuel line (this would be normal since the line in vertical and a little gas would be in it)
When I removed the small fuel line it had pressure on it and squirted gas out .
Is this normal ?
Any help would be appreciated !!
Best Regards !!
Dave
Old 12-10-2013, 09:15 AM
rhandwor rhandwor is offline
Re: Fuel Pressure Regulator -Ruptured Diaphram
I would check for a plugged return line.
The Following User Says Thank You to rhandwor For This Useful Post:
TriumphTigerCub (12-11-2013)
