Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-24-2013, 07:01 PM
Bull632000 Bull632000 is offline
2004 Ford Crown Vic non-police
Hi there!
I have a 2004 Crown Vic with 110k miles. I use it for my winter car and it has been in storage since April this year. When I went to get it out this week, the battery was dead, so I bought a new one. After I installed the battery, I turned the key and let the fuel pump run for a few seconds and the car started right up. There was like a puff under the hood and the car stalled. (just a little puff, like some dirt dropped into the fan) I started the car back up and it was running rough, so I hit the gas with the linkage under the hood and it stalled again. I shut the key off and turned it back on to let the fuel pump cycle and it did not make any noise.
I moved the relays around and still nothing. I pounded on the gas tank with a rubber mallet and still nothing.
Please help. I don't want to start the money dump. The car is in great shape but it this is frustrating. ANy ideas what to check for???
Old 12-04-2013, 05:48 PM
rhandwor rhandwor is offline
Re: 2004 Ford Crown Vic non-police
Originally Posted by Bull632000 View Post
Hi there!
If the fuel pump isn't running are you sure you you checked the proper relay the fuel pump relay used to be green.
Is it labeled fuel pump. You can use a jumper this will supply power to the fuel pump and turn on the pump.
If not sure which terminals use a wiring diagram or use a new relay.
Get a rental pressure gage and make sure before dropping the fuel tank..
