Old 06-19-2003, 11:31 AM
Mr. Death Mr. Death is offline
another sub wiring question
I just aquired a 2 channel amp to power my DVC 4 OHM sub. The load coming from my sub is at 2 ohms with the current wiring. My amp is bridgeable into 4 ohms and 2 ohm stable(whaterever that means!). Will this work or do the ohms have to be the same?
Old 06-19-2003, 06:29 PM
b16a3sol b16a3sol is offline
there are a few things we need to know in order to determine which is the best way to wire your sub to your amp.
1.) power rating of sub
2.) power rating of amp at 8 ohms
3.) power rating of amp at 4 ohms
4.) power rating of amp at 2 ohms
if the rating of the sub matches the amp at 2 ohms, then keep the same wiring configuration you have now and enjoy loud music. if the amp rating is a significant amount higher than the sub, then wire the sub in series and enjoy moderately loud music.
one thing i am not sure about, is whether you can wire one voice coil to one channel, and the other to the other channel. if the two signals are off from each other, they will end up fighting each other and the sub will not be as loud as it should.
in order to get a 4 ohm load, you will need either replace the sub you have now, or get another dual voice coil sub. if you get another dual voice coil sub, wire the voice coils on each sub in parallel, then wire the subs in series with the amp bridged.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 06-19-2003, 06:43 PM
AirAllen01's Avatar
AirAllen01 AirAllen01 is offline
Send a message via Yahoo to AirAllen01
No you can't. If you can give us the model number of the amp and the subs, or the power rating for both, then we can help. Until then, we can't give you the best advice.
Have you ever danced with the Devil in the pale moon light?
I'm your Huckleberry.
Don't hate the playa, hate the game.
Unreal Tournament 2004 Mexican Mafia «MM»Sternum
Visit AF's Sketching and Drawing Forum.
http://www.automotiveforums.com/vbulletin/f1155/
Old 06-20-2003, 06:22 PM
Originally posted by AirAllen01
No you can't.
learn something new every day.
Old 06-20-2003, 06:26 PM
AirAllen01's Avatar
Know what you mean. Me too.
Old 06-21-2003, 11:20 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
actually, you can do that ...... but you need to be good at level matching the amps, or the speaker won't last long
Old 06-21-2003, 12:49 PM
AirAllen01's Avatar
Some people can, and some people can't. I prefer to go ahead and tell them no because most ruine their speakers doing that. If you can, then you can go for it.
Old 06-22-2003, 04:44 PM
its seems like it should be fairly straight forward process.
1.) hook up one amp and set a gain level
2.) determine the current leaving amp with DMM
3.) unhook amp and wire up the other amp
4.) adjust gain until current is at same amperage as original amp
5.) wire both amps up and enjoy the music
the part that i would be lost on is how to determine where you want the first amps gain to be set at.
Old 06-23-2003, 05:42 PM
Audio Guy
actually the level setting can be even easier than that ....... feed an inverted signal to one of the amps - then just adjust the levels (while both amps are playing) so the speakers doesn't move at all. Remember to use fairly low signal level for this - and THE SIGNAL MUST BE MONO.
Old 06-28-2003, 12:20 AM
very nice idea...
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
Another Wire Question - Oil Pressure PeteA216 Caprice 7 05-18-2007 11:10 PM
Another Sub Folder highteknology COMPLETELY off-topic 14 07-15-2005 07:33 PM
Another Overhead Console Wiring Question... Booch Blazer 1 06-03-2005 06:48 AM
