Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-20-2013, 06:13 PM
thegreenhornet95 thegreenhornet95 is offline
heater core problems
I have little or no heat. Both lines to my heater core are hot. Can it still be clogged some how. I've checked my door actuator and it works fine. It doesn't run hot either and it have a new thermostat too. Can it be the core?
Old 11-21-2013, 01:32 PM
j cAT j cAT is offline
Re: heater core problems
if the heater core hoses are hot and no heat then the TEMP DOOR IS STUCK ...inside the air box at the top of the tranny hump..
Old 11-23-2013, 07:05 AM
Thanks
Old 11-23-2013, 09:35 AM
Tech II Tech II is offline
"I've checked my door actuator and it works fine."
Than it's not stuck, it's broken(linkage)....MAJOR job....
Old 11-23-2013, 09:50 AM
What's Broken linkage?? Is it in the wiring?
Old 11-23-2013, 02:03 PM
I forgot to mention that i only have heat in park but as soon as i start driving it gets cold
Old 11-23-2013, 03:10 PM
with this problem what is the engine temp with good heat and when you start moving and loose heat..
I have seen bad/wrong thermostats cause this problem. the engine temp should be 195 deg f . the temp will not move it locks in at the temp. if when moving it drops then the thermostat is bad or the wrong one. could also be screwed up as well on the install.I have had bad new thermostats ...
Old 11-23-2013, 03:19 PM
The temp goes up to about 210(half way) and drops down to 195
Old 11-23-2013, 06:30 PM
777stickman 777stickman is offline
Please tell us what vehicle you're working on. Year, Model, Engine, A/C or not, etc.
Also tell us how your door is actuated. Cable, vacuum or electrical.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-23-2013, 11:04 PM
My heater core wasnt in the right position. Thanks anyway fellas
Old 11-24-2013, 07:58 AM
aleekat aleekat is offline
what does this mean?
Post back, that's what makes Forums Work.
Old 11-24-2013, 08:28 AM
so the heater core was in the wrong position and this caused the temp door to not move to the heat position ?
how did the heater core move ? does it look like someone screwed with it ?
Old 11-24-2013, 08:44 AM
This answer will be interesting......I have an idea what it is....
Old 11-24-2013, 02:55 PM
Who ever installed it before i bought the truck moved it out of position to keep heat out of the cab because it didn't have A/c or didn't know how to install one in the first place
Old 11-24-2013, 03:24 PM
this was installed wrong . if he did not want any heat bypassing the heater core is what would be done at the engine heater core hose ports.
with high humidity you would need some heat to clear the condensation off the windshield..
