Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 11-18-2013, 11:59 AM
sbagdon sbagdon is offline
'03 ZX2 Catalytic Converter 49 vs. 50 state?
Have a huge chunk missing from the cat pipe, between the rear O2 sensor, and the cat. Planning on pulling the pipe, then pulling the two O2 sensors, then putting in a new cat pipe.
Appears that there's two versions, 49-state (no CA), and 50-state (CA). So for Walker, the 49-state is the 52284, and the 50-state is the 82673.
Yet... what's the difference between the two? Is there a significant difference, such as 1 vs. 2 O2 sensors, or is it something as mundane as you're paying for the CARB sticker?
Will check under-hood for a CA-sticker (we're in MI), yet hoping someone knows what the practical difference is, between the two. Thanks!
Old 11-18-2013, 12:22 PM
rustydogy's Avatar
rustydogy rustydogy is offline
Re: '03 ZX2 Catalytic Converter 49 vs. 50 state?
as long as you are registered in mi get the cheeper 1 the only real diff is 1 is ca certified and ca will look to ckeck
Old 11-18-2013, 12:34 PM
That's what I figured. This ZX2 has two O2 sensors, so I was worried that the number of O2 sensors was the issue. I say that, in that I have an early '90s vehicle that the difference between 49-state and 50-state, was 49-state was one O2, and 50 was 2 O2's. If it's just a CARB sticker, and it's registerd in MI, figure they'll stick with the 49-state. Thanks!
Old 11-18-2013, 12:50 PM
rustydogy's Avatar
I just looked some info on this you take a look http://catalog.walkerexhaust.com/cat...partKey=781009 you may have to copy and past link but you will see by looking up each part # click on where it( says site map ) follow down left side of page and enter part #
The Following User Says Thank You to rustydogy For This Useful Post:
sbagdon (11-18-2013)
Old 11-18-2013, 01:16 PM
That url or part number doesn't take me anywhere (tried cut-and-paste).
I looked up that vehicle, directly, and the cat comes up as 52284, with the note "As of January 1, 2009, converters in this catalog can not be sold or installed in California.".
Ok, did the obvious... called Walker technical support. They state that the 49-state is physically compatible, the 50-state is stamped to warrant that it has gone through the CARB certification process. So a CA car in MI can physically use the 49-state unit. I'll go with that's an authoritative answer. ; )
Old 11-18-2013, 01:58 PM
rustydogy's Avatar
sorry the link did not work but that link took you to walker to look at and tell the diff but now you know Ca. just wants more money for the same thing
Old 12-25-2013, 12:50 AM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
Cali is REALLY strict about CARB approval. What he said doesn't surprise me.
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
