Old 11-17-2013, 05:36 PM
makuloco2000 makuloco2000 is offline
No Heat Common Causes?
Here are the most common problems if you find yourself without heat this winter season. Hope this helps!
Old 12-09-2013, 01:14 PM
dannon6 dannon6 is offline
Re: No Heat Common Causes?
All - please be aware that the heater core contains numerous passages (10-20) through which coolant can flow, so just because you were able to flush the core in both directions, doesn't mean that it's clear. You could be getting flow through half of the passages while the other half are still plugged.
Old 12-09-2013, 11:18 PM
Yes as I can attest to this have seen it multiple times.
