Go Back   Automotive Forums Car Chat > Ford > Super Duty
Old 11-17-2013, 06:27 PM
makuloco2000 makuloco2000 is offline
No Crank/No Start in Park
Forgot about this common issue with the Superduty and Excursion vehicle that while it won't leave you stranded, it is a pain to live with. It has to do with the shift linkage bracket bolts coming loose and losing the shift cable adjustment as a result. Check out the video, as you will likely run across this at some point in your ownership of the Superduty. I hope my video helps!
