Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Classifieds
Old 11-17-2013, 11:42 AM
SleepnZJ SleepnZJ is offline
FS, Factory NOS parts, T-case, manual rack, Heads, Big 16g
I'm clearing out all of my DSM parts to make room.
I have a bunch of new old stock factory Mitsubishi parts, all prices are negotiable and I can ship all the parts except for the lot of 5 cylinder heads. Prices do not include shipping.
Two, New 2G ring sets, MD313405. $130 each.
One, new 1G ring set, MD140923. $150
One set of 4 new 2G pistons with wrist pins. MD 307819 $250
One set of 4 new 1G pistons .50mm over sized, pulled from a factory remanufactured engine. $150
Three timing belt adjusters for 7bolt motors, MD308586. One of them has a little surface rust from the package being open so I will take $40 for it. The other two are $80 each or I can take $170 for the lot of all 3 of them.
One timing belt adjuster for a 3000gt, MD3199040. $70
Three 2G fuel filters, MB868457. $15 each
Two 1G fuel filters, MB504761. $15 each
7 bolt engine bearings set, 1 pair MD343331 thrust bearings, 4 pair MD195939 rod bearings. $90 for all
Early 6 bolt straight cut oil pump gears, MD121120 and MD125361. $70
One factory new manual steering rack, no brackets or tie rod ends. $150
One used Big 16g Turbo, It is has a ported turbine housing and a powder coated compressor housing. Minimal shaft play. The turbine housing has some cracks and one of the oil drain flange bolt holes has been re-tapped because the old bolt broke off in the housing. $100
One used 2G exhaust manifold, it was cleaned up and bead blasted, it does have some cracks in outlet flange. $40
One factory new 23 spline transfercase, $500
Two, Used 23 spline transfer cases and one used 22 spline transfer case, $50 each
One factory new talon rear end panel, $20
Five used cylinder heads. two of the heads are bare, one of which is semi ported, the three other heads have valves in them but I cannot attest to their condition so consider them as needing to repair. $175 for the whole lot.
http://s296.photobucket.com/user/Sle...?sort=3&page=1
