Go Back   Automotive Forums Car Chat > Mitsubishi > General Discussion
Old 06-18-2003, 09:07 PM
drnik78 drnik78 is offline
Question need to know what is the BIGGEST motor i can fit in my 95 eclipse ,the easiest.
i need to know if i can put any other mitsubishi motor with more power then my 2.0 ?or any other motor any suggestions would be appriciated.
Old 07-16-2003, 02:42 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
If you have a turbo 2.0l .....size is not a restricting factor. I put down PLENTY of HP with my 2.0.
Kris
2012 Genesis Coupe 2.0t
Old 08-26-2003, 03:14 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
There is a 2.4 liter that uses the same block I think, I know its pretty much a direct swap.
Old 09-29-2003, 01:26 PM
ttzuke44 ttzuke44 is offline
he is right there is a 4g64 motor that is from the same family hence it is the same block. However the only ones that will put down more power are the new one in the Spyder but you can purchase an old one from a Mitsu. Mighty Max or a Montero and due swap or custom parts.
Old 11-04-2003, 10:54 AM
44hondaeater 44hondaeater is offline
NSX Swap
Hey on the 00+ Eclipse forum there is someone that put an NSX engine in his eclipse. I don't know the details but it might be something worth checking out.
03 Kapalana Black Eclipse RS
Performance:
Eibach Pro-Kit
ICW Racing 17" Fishbone Rimes
Kumho Ecsta 711 215/40R 17 83 H Tires
Tsudo CAI
Ractive Cat-Back Exhaust
Advance Pergormance Piggy Back Chip
LOOKS:
JSp MotorSports 2 Stage 59" Carbon Fiber Wing
VIS Carbon Fiber Evo VII Hood
Red Dash Light Conversion
In The Future:
TURBO
Old 11-04-2003, 11:02 AM
Re: NSX Swap
A mid-engine setup in a front-engine fat, ugly car...this I have to see.
Kris
Old 11-05-2003, 03:49 PM
ItsyBitsySpyder ItsyBitsySpyder is offline
Thumbs up
you could always get a 4g64 motor out of a 96-99spyder and turbocharge it, it puts out 141hp with 147ft/lbs torque STOCK for a SOHC. get either a 16g or 20g turbo and bolt it up on there. a good motor if you ask me, but you can't rev it past 6500 rpm's(longer bore & stroke, it can't handle it)
Old 11-08-2003, 03:59 AM
AceClips AceClips is offline
Re: need to know what is the BIGGEST motor i can fit in my 95 eclipse ,the easiest.
You can do a VR4 swap in the eclipse but if u have a GSX it would be a lot easier although it will run you about 25 Grand for everything i know a guy who did it over seas with upgrated turbos its a very tight fit but it does fit and the power omg i could describe it even if i wanted 2 lets just say 1/4 mile 9.32 at 156 mph
Old 11-08-2003, 04:04 AM
911S_TARGA_RSR 911S_TARGA_RSR is offline
Re: Re: need to know what is the BIGGEST motor i can fit in my 95 eclipse ,the easiest.
A Hamster!
911 Super Targa RSR
[Dual Flow Intake][Twin Turbo][Larger List to Come]
I'm working on the VR4 swap in my eclipse i just need to find a cheap wrecked VR4 and i got it from there on ill do all the labor which is very expensive in custom swaps and buying new engines and trans is very expensive it should not run me more than 10 Grand around there thats because ill be rebuilding the trans, engine, upgrate the turbos, etc.
Old 11-10-2003, 07:04 AM
Re: Re: Re: need to know what is the BIGGEST motor i can fit in my 95 eclipse ,the easiest.
Originally Posted by 911S_TARGA_RSR
A Hamster!
I'd love to see what my hampster can do against your German machine. Quit being a troll and move back to a forum where childish cracks like that are funny.
Kris
Old 12-23-2003, 05:27 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
FIRST which model eclipse do you have if its a RS/GS your screwed unless you have crazy money if you have crazy money buy a new car for cheaper than a swap in a gs if u have a gst/gsx what more are you looking for if u want to spend money on a motor swap just dump it into the motor the amount of money u are talking about u could easly have a 11sec car
Old 01-08-2004, 02:13 PM
intensentn intensentn is offline
Guess that means no 454 in my expo
Cracked Radiator, what other ar radiator can fit? J_J_T Grand Prix 3 03-04-2006 10:03 PM
Does anyone know what kind of HID bulb fits on a 2003 Tacoma Prerunner? jidsp Tacoma 3 11-03-2003 08:32 PM
what's the biggest motor and trans swap for a 89 civic si? droppedcivicsi89 Engineering/ Technical 2 10-27-2003 08:44 PM
Who Said the Teg motor didnt fit slammedcivicsi '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-22-2002 01:32 AM
