Old 06-18-2003, 05:18 PM
Drewbu Drewbu is offline
water build up
Hi...
I really need help ...
I had this problem for long time now!!!.. over 4 months
water builds up under carpet on passenger side of my blazer (98 2dr) and it gets REALLY wet i used shop vac to suck it out it filled it up... and it smells bad ...
please help ...
Old 06-18-2003, 06:24 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
What color is the water clean or dirty? This will tell you if its coming from up top or down below. But I suspect that you have a clogged evap case drainwhich fills up the air conditioning box with water and it overflows. You need to make sure your drain is free. Look under the hood near the firewall on the passenger side about 12 inches down will be a drain. Alsoyou can pull up the carpet and see if you can see where its coming from. Does the water appear after a rain storm?
Old 06-18-2003, 11:07 PM
I can't say if it's clean or durty for sure but it's not clean
Yes it builds up after rain storm....
I'll check the drain... in the second...
Thx for info
Old 06-18-2003, 11:25 PM
I looked i couldn't find the drain ...
can you explain where is it again... plz ....
Old 06-18-2003, 11:42 PM
pcv pcv is offline
Do not worry about the drain. Looks like you have a leak along you windshield or door frame as water rolls down and somehow gets into the vehicle. Spray water with a hose and look for leaks or water marks inside the car. Follow the leak and repair as required. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 06-19-2003, 12:29 AM
Thx i'll try that tomorow ...
Old 06-25-2003, 07:52 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
It's more likely your heater core if it's on the passenger side... Check your coolant levels, they are probably low...
Old 06-25-2003, 08:11 PM
carquestman's Avatar
carquestman carquestman is offline
Send a message via AIM to carquestman
Lightbulb water
rlith is probably right check coolant levels to make sure your not low
if not you may have a water leak from the door seal or mafrom underneath pull up your carpet in the corner and look
Old 06-26-2003, 11:48 AM
Thx
Thax to all of you,
my door was leaking, i fixed it .....
thank you
Old 06-26-2003, 09:58 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
if you think it may be the heater core, turn on the heat full blast on defrost and see if it fogs up your windows, and smell the air coming out if it smells sweet it's probly the heater core.
