Old 06-18-2003, 12:43 PM
Mr. Death Mr. Death is offline
Testing plug wires
Is there a way to test plug wires to see if they need replacing?
Old 06-18-2003, 05:29 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
voltage meter.....the chilton manual has spec for testing plug wires
Honda...An Army Of One
Old 06-18-2003, 05:33 PM
sooboss's Avatar
sooboss sooboss is offline
If you dont have a volt meter park you car in a garage and have some one rev your engine if you see your wires arcing they're bad. good to do this at night. Or check this individually pull them out and ground them.. to see if you even have spark.. volt meter is the best though
Old 06-18-2003, 05:49 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
or just hook a timing light to each one at a time. if one is obviously flashin the light slower than the others, then its bad, or the spark plug is bad
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
