| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
97 rodeo 2wd 5 spd no power to the wheels w/ engine running
I was driving on the freeway about 65mph when, without warning, I had no power to the rear wheels. Pulled over and put it in first, let out clutch, nothing, drive shaft not turning. Any ideas?
Thanks T CF |
#2 | |
Re: 97 rodeo 2wd 5 spd no power to the wheels w/ engine running
Sounds like either a clutch failure or a transmission issue, e.g. sheared input shaft.
#3 | |
If it were clutch failure, wouldn't I have some warning, ie clutch slippage, smell?
#4 | |
Yes, typically the clutch will begin slipping before it finally fails and you would be able to smell it. However, if there was some catastrophic failure with the pressure plate or friction disk, it could also be the culprit. Not sure how mechanically-inclined you are, but this is most likely an inspection cover that could be removed so you could visually inspect the clutch. If there was a catastrophic failure, there would be fragments of clutch material laying at the bottom of the bell housing. From this vantage point you should also be able to view whether the engine's flywheel is turning, confirming there aren't any issues further upstream, e.g. crankshaft issues. If the engine is turning the flywheel and the clutch appears in good shape, then it's most likely a transmission issue, e.g. broken input shaft or some other internal failure. Hope that helps and if you decide to do your own inspections, properly block the wheels or secure with jack stands to prevent injury to you or others.
#5 | |
Thanks for the info. Am going to jack up the front and put jackstands under it to remove inspection plate tomorrow. Will post what I see or don't see.
#6 | |
So did you ever figure out what happened?
