Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-11-2013, 08:09 PM
nuckolsk's Avatar
nuckolsk nuckolsk is offline
NUCKOLS
Torque sequence lower intake 2000 ls v6
Does anyone have the torque sequence on the lower intake for a 2000 ls v6 ?
Old 11-11-2013, 08:11 PM
old_master's Avatar
Advisor/Moderator
Re: Torque sequence lower intake 2000 ls v6
You have to know how it works,
to figure out why it doesn't.
Old 11-11-2013, 08:16 PM
nuckolsk's Avatar
NUCKOLS
Only 4 bolts on lower
Old 11-11-2013, 08:19 PM
old_master's Avatar
Advisor/Moderator
Nope, 8 bolts. Threads MUST be chased on the bolts, and in the heads, and sealer applied to the bolt threads. If you don't use sealer, #1 they will leak, and #2 they will "walk out" due to the low torque.
Old 11-11-2013, 08:26 PM
nuckolsk's Avatar
NUCKOLS
4 only on lower fel pro gasket #ms96475, 8 on upper fel pro gasket ms96483, lower is plastic and fuel rail mounts to it, upper is aluminum.
here is upper info just have no lower info
Install the upper intake manifold bolts and tighten in the sequence shown.
Old 11-11-2013, 08:45 PM
old_master's Avatar
Advisor/Moderator
Sorry, my mistake. Misunderstood what engine you were working on. Please disregard info. Does not apply to your engine.
Old 11-11-2013, 09:36 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Check your inbox.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
nuckolsk (11-11-2013)
Old 11-11-2013, 09:37 PM
nuckolsk's Avatar
NUCKOLS
Thumbs up Re: Torque sequence lower intake 2000 ls v6
Thanks as always for the help shorod, your the best !
