Go Back   Automotive Forums Car Chat > Pontiac > G6
Old 11-11-2013, 03:38 PM
agginamI agginamI is offline
2007 g6 stereo/radio harness problem.
So a few days ago i got a new stereo unit for my 2007 Pontiac g6, in the process i replaced some of the wiring harness connections. i tested these with an ohm meter and measured no resistance, and tested them with a test light as well, however neither stereo unit turns on when connected. I'm quite sure i followed the correct steps when replacing these as well as got the connections correct. Any insight as to why they wont work?
Old 11-11-2013, 09:05 PM
Tech II Tech II is offline
Re: 2007 g6 stereo/radio harness problem.
Well, it's obvious something is not wired right.....I don't know how you can expect us to venture a guess other than that, or figure out what you have done wrong?
Now if your wiring is correct, there is the possibility of a bad new radio....
Old 11-12-2013, 12:01 PM
Well for instance is it possible i blew a fuse/short circuited something? if that's the case i wouldn't know what fuse it would be/what would have gotten short circuited. which fuse box would the stereo fuse be in
