Old 06-18-2003, 07:44 AM
Civicsiassasin91's Avatar
Civicsiassasin91 Civicsiassasin91 is offline
Send a message via AIM to Civicsiassasin91 Send a message via Yahoo to Civicsiassasin91
Im runnin' hot Can't figure out why
Im cruising along yesterday and i happen to see my check oil light come on.. Im like ahh shit. I check my oil and its mad low. So im like bet ill do an oil change tonight. on the way home i notice that my Temp guage is goin up. I usually stays about 1/4. Now its at about 1/2-3/4. i let the car sit overnight cause i thought that maybe the guage will go down after coolin off for a night but this morning the needle was still at 1/2 !! So im like what the fuck. Oil is good.. coolant is good. my fan works. What am i missin??
I wilst judgeth thou, as long as thou posteth gayeth topics on the internet.
TLD's FINEST
Old 06-18-2003, 08:01 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
k how long did u let it sit ? if the engine was cold and the gauge still read 1/2, then your gauge is off. and when u first start yoru car the next morning and the gauge read 1/2, did u let it run alittle and see if it dropped ? because the gauge will read alittle bit less than what it was when u shut it off, so when u start it the next time, you gotta wait and see if the gauge drops. did u wait to see if it dropped or did u start it up real quick and see the gauge then quickly turned it off ? because if u did that then try start it up and wait and see if the gauge ddropped
Team Lonely Drivers
Old 06-18-2003, 12:44 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
try bleeding the coolant system if that isnt the problem and then check your thermostat for starters if it isnt the gauge problem
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-18-2003, 03:04 PM
I fixed it. i just replaced the thermostat this morning before i went to work and its fine. I can't understand why needle didn't go back down after sitting all night but whatever. Its fine now
thanx
TLD's FINEST
