Go Back   Automotive Forums Car Chat > Mercedes-Benz > C-Class
Old 11-10-2013, 08:32 PM
gatliffe gatliffe is offline
Question Cam timing 95 C280 pin hole line up
I had to replace the head on my 95 C280 now I need to set the cam timing I understand you use a dowel pin 4mm in the gear hole but fist it seem the holds are much more then 4mm and there are 3 holes on the one gear what hole do I use and do you set the motor to TDC
Tags
cam , mercedes , timing
