Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 11-10-2013, 02:57 PM
GeoRandy GeoRandy is offline
Exclamation Engine Clean Up - Never Wash
The owners manual says not to use a water hose or water pressure to clean your engine. I now know why. The spark plug wire boots do not keep water from getting under them and the water goes down around the spark plugs. The cavity that the spark plugs are in fills and holds the water. Not knowing that (after washing the engine) I started the car and instantly got a check engine light. The spark plugs were completely under water and it fried the ignition coil (where the spark wires plug in, not a distributor but similar in appearance to a distributor cap.) Anyway, I ended up replacing all 4 plugs and a new ignition coil. $20 for the plugs and $80 for the ignition coil. Runs good again but was a $100 mistake on my part. All I wanted to do wash clean the engine and compartment. They don't make cars like they used to. I just don't want to see anybody else make that mistake.
The Following 2 Users Say Thank You to GeoRandy For This Useful Post:
Mr. Music (06-21-2014)
Old 06-21-2014, 07:43 AM
Mr. Music Mr. Music is offline
Re: Engine Clean Up - Never Wash
Well, that definitely made me change my mind about doing this.
Thank you for posting!
