Old 06-17-2003, 11:57 PM
Fewman Fewman is offline
Send a message via AIM to Fewman
coilover problem
Alright, so we just recently replaced the left and right axle and a few days later my problem occured: Whenever I go over a bump, there is loud rattling coming from my front left wheel area. We raised the car to see what's going on, and noticed we can move the left coilover up and down (not the spring, the entire thing). None of the other coilovers shake like this or make any noise like this, just the left one. I also noticed some rubber was lose at the base of the coilover. I know next to nothing about coilovers, so any help would be greatly appreciated =).
Old 06-18-2003, 12:04 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Is there compression on the spring? Does it just kinda float around while driving or does the car actually rest on it keeping it compressed?
Old 06-18-2003, 12:05 AM
The spring is nice and tight, while the car's up and while it's down. The whole thing will shake up and down. Did I mention the coilover doesn't shake up and down while the car's not in the air? It's only lose when it's raised....
Old 06-18-2003, 12:25 AM
BullShifter's Avatar
What kind of coilovers? sleeves or real?
forgive my ignorance, but what's the difference? How can i tell...
Old 06-18-2003, 12:32 AM
Sleeves are coil springs with a threaded collar used on stock or performance shocks. not so good
Real coil overs are basically the same thing but they are engineered to work together. Usually costing atleast $750. These are wonderful
Old 06-18-2003, 12:35 AM
How do you mean work together ? My springs are definately not stock, and my coilover is threaded with two bolts that i loosen to move up and down to lower/raise my car. They are not attached if that's what you mean...
Old 06-18-2003, 12:51 AM
Real coil-overs
Sleeves/coil over springs
I hope this helps
did you put the fork bolt back in?
Old 06-18-2003, 12:54 AM
chopstick1981 chopstick1981 is offline
id check those little rubber grommets hooking your suspension up to the shock tower. When i first installed my coil-overs i somehow forgot the grommet on top of the shock tower and it rattled when i hit bumps.
Old 06-18-2003, 01:25 AM
I think chopstick might be close to what the problem is, I'm not sure how to get them back in though. They are the "not real" coilovers, I guess the previous owner got cheap ones, so whatever. Do you know how to fix the rattle or is there a howto on it chopstick?
Old 06-18-2003, 12:33 PM
can anybody help me? Please?
Old 06-18-2003, 04:55 PM
What the hell is a chopstick??
khanair khanair is offline
Send a message via AIM to khanair
ok, the sleeve coil over's spring isnt compressed when the control arm extends down into a pothole or other various low spot. thus making his noise. the strut fork is back inplace and secured. also, it cant be moved. we tryed to lift the LCA up but all it did was move the whole suspention. my thoughts are that either the locking nuts on the sleeve were moved. or the strut tower itself got bent somehow. the noise didnt start till yesterday morning, but im not too sure what it is, i mostly work on domestic older american cars.
Old 06-18-2003, 04:56 PM
the member that posted an answer...
coilover kit help suzuki19 Performance 0 05-16-2010 01:23 PM
Coilover problem Medez13 Wheels/Tires/Suspension 2 08-03-2004 07:03 PM
coilover problems? supratuner Accord/TSX/Accord Hybrid 0 11-09-2002 06:11 PM
Coilover Problems! Accord_Racer03 Accord/TSX/Accord Hybrid 2 11-01-2002 12:02 PM
