1992 camry wont start, it turns over very freely I think it is the fuel pump or relay. no buzzing noise under the car with the key on, what are some tests that can be done to find out the issue?
-dave |
Re: 92 camry wont start
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
I got it started and then it cut out on the road.
-dave |
It ran for about 15 minutes parked and then cut off and now no spark. the cap and rotor are new so now it is time to find the coil, is it under the cap or something?
-dave |
Yes, the coil is under the cap. Mike |
| The Following User Says Thank You to Mike Gerber For This Useful Post: | ||
vitalmuncie (11-06-2013)
If it's a California car and if it's a four cylinder, the coil is on the fender.
| The Following User Says Thank You to Brian R. For This Useful Post: | ||
not a california car I dont think but it is a 4 cylinder with only 4 contacts on the distributor cap(nothing for a coil wire).
-dave |
Brian is correct. The fact that it was a 4 cylinder non-California car was a bad assumption on my part. Thanks for the clarification.
Mike |
