Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 06-17-2003, 06:44 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
how do i hook up this two wire neon
Hey, i got a 12" neon light, with a positive wire and a negative wire, how would i go about hooking it up to my car, do i need to fuse the positive wire, and ground the negative wire.....?
Old 06-22-2003, 03:58 PM
BootyDC316 BootyDC316 is offline
+ wire to a hot wire, any wire powered from the battery and the - wire to either the chassis, a good screw, or splice into another ground wire....
Yeah yeah you know I'm fly!
Old 06-22-2003, 07:23 PM
jeffseby's Avatar
ok, great, thanks, i figured it was that easy, i just wanted to make sure.
Old 06-24-2003, 02:52 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
how would you wire a toggle switch into that? what wire would you cut and solder to the switch?
I was told i could wire them into the cigarrete adapter line, but i'm not sure how many that could hold? any idea? I got a 9", a 12", a 9", a 9", and another 12" all on seperate lines.
Name's David.
Old 06-24-2003, 05:03 PM
jeffseby's Avatar
do not do all that on a cigg lighter, use your battery, and run it throunh the fire wall, or if you got $25 laying around, put that battery behind you seat, and wire your neons, to that, i used a toggle in the positive lines.
Old 06-24-2003, 07:34 PM
$25?
I don't know which light's work anymore but i can test them by touching each line my battery right? I still can't figure out the $25 thing.
Name's David.
Old 06-25-2003, 03:53 PM
jeffseby's Avatar
ya for $25 just put a cheap battery in your car, and hook the lights up to that.
Yes you can touch wires directly to the battery to test the lights....
Old 06-25-2003, 08:59 PM
when i put my optima battery i think i'll use the one i have now and put it in my trunk somehow.
Name's David.
