Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-04-2013, 11:35 PM
bsherb bsherb is offline
starting problems
I have a 98 k 1500 with a 5.7 and 148,000 miles. Last week when I went to start it it only clicked. Turned key off and back on and started normally. was good for several days then did it again. Now it just took 8 tries before it started. Battery is good, alternator is good and checked/cleaned battery connections. No luck, still doing it. Is my solenoid going out? It is original starter.
Old 11-05-2013, 12:17 AM
mopar man's Avatar
mopar man mopar man is offline
Re: starting problems
if its just clicking it could be the selenoid on its way out your lucky its giving you a "hint" usually they just quit all together when you least expect it and with that many miles on a original starter it wouldnt hurt to replace it a little preventive measure as I like to call them if ya dont wanna spend the cash get it pulled off and have it checked out
I stepped on a Cornflake, and now I am a cereal killer.
Old 11-05-2013, 08:35 AM
j cAT j cAT is offline
when it fails hit the starter , with the key to crank . if it starts cranking replace the starter .. first I would make sure all connections and the one going from the solenoid to motor is secure and clean.
Old 11-05-2013, 12:05 PM
Yeah thanks. I think I just need to replace starter and solenoid since it has 148000 miles on it. Not really looking forward to it though.
