Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-04-2013, 10:04 PM
bsherb bsherb is offline
tahoe heater problems
can anyone tell me where the heater control valve is located in the '97 Tahoe? Also what odes it look like?
Old 11-05-2013, 07:31 AM
j cAT j cAT is offline
Re: tahoe heater problems
what is your heater issue ? there is NO VALVE .
Old 11-05-2013, 11:08 AM
The issue is not able to get defrost, seems to be stuck on vent. Multiple threads say the heater control valve is the problem.
Old 11-05-2013, 01:52 PM
if your stuck on vent then this maybe on a 1997 the vacuum lines.. not sure with that model year. now with the 1999- up they use motors to open these vent doors.
look under the hood for any vacuum lines running to the air box and other controls . should be 5/16 inch hoses...same under the dash ...then you may have to open up the duct work could be debris causing this issue as well..
Old 11-06-2013, 06:05 PM
777stickman 777stickman is offline
'98 & '99 Tahoes & Subs have what's called a "Water Valve Actuator". Not sure about your '97. Doesn't really matter any way as it has nothing to do with your issue of no defrost. Your issue is with the "mode control" door (floor, vent, defrost). This door can be controlled 1 of 3 ways. Vacuum, cable or electrically. The "electric" control motor is located under the dash on the left side of the heater plenum just to the right of the gas pedal.
Have a look and let us know what you've got.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
