Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-17-2003, 02:28 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
Which Fuse Do I Remove...
Which fuse do I remove to kill the lights on my cluster? See I passed emissions in CA a month ago I got to AK and my engine light turned on and I failed the visual part of my inspection. I was gonna remove the fuse and take it in cause I know I will pass now I just need to know which fuse to remove to kill the lights. Thanks!
btw I have bad 02 sensor thats why light is on...
Darrell
thegrumpysergeant.net
Old 06-17-2003, 02:56 PM
BigBoyB's Avatar
BigBoyB BigBoyB is offline
same thing happened to me on my old car. if you simply remove the fuse (i dont know which one) it will not pass anyways because part of the visual test is having the check engine lite come on for a second while starting up the car. I got passed this by disconecting my battery for a second. the system did not recognize the reason for the check engine light to come on. do this and see if it works for u. but the light eventually will come back on in a day or two hope it works for your teg it worked for my ford ranger
lets roll[/font][/size]
Old 06-17-2003, 04:22 PM
AF's #1 Bad Guy
Thanks bud
Darrell
Old 06-18-2003, 12:12 AM
92teggsr 92teggsr is offline
take the backup fuse(located under the hood) out for at least 15 seconds and then put it back in. It resets your ecu and it'll take a few minutes for it to recognize that your O2 sensor is bad. Your check engine light will still come on for a second when you start your car. Make sure you do it right before you take that visual test though.
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
