Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '88 - '91 Civic | CRX | Wagon | Shuttlee
Old 06-17-2003, 03:00 PM   #1
Tony
TLD Member #1
Tony's Avatar
Send a message via AIM to Tony
Someone enlighten me on Tire pressure setups
Alright, lately me and Civickiller have been trying to figure out exactly how and why tire pressure setups work. We both understand that at a drag race, the lower tire pressure allows the tire to grip faster, but from his experiences, it also slows his 1/4 mile time down. While a higher tire pressure slows down his 60 foot time, it cuts down on his 1/4 mile time.
Now this is where I keep getting confused, knowing that a lower tire pressure should increase grip, or atleast at a track. I know it doesn't increase grip when you start turning. I have messed with tire pressures on my car, and at first before I tried reading anything on it, i figured i would set my tire pressures down and see how much more grip I would get. I was wrong, I lost grip. So I took the liberty to actually read something on tire pressures at www.SportCompactWeb.com and they helped some explaining it to me. But I'm still tryin to figure out why there is such a difference between drag setups and road racing setups. Anyone able to help me out here.
Tony
91 Civic Sedan DX - Stock 287k Miles
Tony is offline   Reply With Quote
Old 06-17-2003, 05:54 PM   #2
crxlvr
Slowest Automatic Civic
crxlvr's Avatar
Send a message via AIM to crxlvr
at a drag race, you want all of your grip on the start, races are won or lost in that first 60', while as in road racing, you need consitant grip throughout the race, not in a straight line.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
crxlvr is offline   Reply With Quote
Old 06-17-2003, 10:04 PM   #3
MyFirst4G
MyFirst4G's Avatar
Send a message via AIM to MyFirst4G
hmm..... i was wondering about this too, and i'm with scott..... cause it makes sence!!!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
MyFirst4G is offline   Reply With Quote
Old 06-17-2003, 10:19 PM   #4
silver89civic
Send a message via AIM to silver89civic
besides tire pressure, the type of tire is also very important
the tire's material & rating make them stick or take corners better, but i heard a set up of 30-35psi in the front and 35-40 in the rear is suppose to be ok cuz then the front tires wont have to drag the rear tires *supposely*
Honda Rules!
http://www.cynoptics.com/tldrivers/1024.htm
silver89civic is offline   Reply With Quote
Old 06-18-2003, 10:10 AM   #5
crxlvr
crxlvr's Avatar
well if you are running street tires at a drag race, you run about 15-20psi up front and like 30-35 rear, no need to lower the pressure on non drive tires.
drag slicks you want at about 5-8psi for ultimate grip, since they have no tread, the more tire touching the ground the better.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-18-2003, 10:45 AM   #6
redmanjd
when you drop tire pressure it is also ment to give you more sidewall flex . so that the walls give before traction. you realy dont want to go lower than 25 on street tires because the walls arnt made to handel that exesive flexing and also the tread will start to cup and you will lose tread contact
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
redmanjd is offline   Reply With Quote
Old 06-18-2003, 10:47 AM   #7
Rufes1
Rufes1's Avatar
Send a message via ICQ to Rufes1
yes but also the increase in drag at once your at the later half of the 1/4. the lower tyre pressure only helps you launch where the tyrse slip. Once the tyres jave gripped and you moving the lower preasure increases roling friction.. drag... thats why your 60' times will be better and 1/8 - 1/4 worse..
Rufes1 is offline   Reply With Quote
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
