Old 11-04-2013, 10:12 AM
mjm4200 mjm4200 is offline
1998 windstar no reverse
I recently bought a 1998 ford windstar, and it has no reverse, it also will shift out of gear and into neutral when coming to a stop.i was wondering if this could be the shift solenoids or if the tranny is bad. Any thoughts would be appreciated.
Old 11-23-2013, 05:46 PM
wiswind wiswind is offline
Re: 1998 windstar no reverse
It 'could' be the linkage and Neutral Safety Switch (aka Transmission Range Sensor) are not aligned correctly with the transmission.
When you move the shift lever, you move a cable that connects to the Neutral Safety Switch that is mounted on top of the transmission.
Inside the switch are many contacts that indicate what gear you have selected and the computer energizes the correct solenoids.
There is also a shaft that goes down into the transmission from the Neutral Safety Switch to engage the parking pawl when you move the gear select lever to the PARK position.
So, as it is know to be a high failure item AND is easier and cheaper to deal with.....I would look to the Neutral Safety Switch first.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
