Old 06-16-2003, 10:33 PM
Dx18704 Dx18704 is offline
Send a message via AIM to Dx18704
Question Wetsanding?!?
Yea i was wondering if i was to wet sand the hood of my car cause it has like really bad oxzidation it looks as if i put wax on and never got it off i tried differnt types of waxs and oxzidizer and still no dice do you think that wet sanding it would fix it? any input is welcomed
\m/ (-.-) \m/
Rock and Roll will never die
Old 06-16-2003, 11:05 PM
BullShifter's Avatar
Depending how bad the damage is, yes wetsanding will remove heavy oxidation. To do this you will need wet sand paper(fine grit), Heavy compound, medium/light compound, polish, wax, & a HIGH SPEED buffer. Doing it by hand will never get the job done perfectly.
Wet sanding is only needed in sevre cases. Heres the process
1. wash/dry car out of direct sunlight
2. wet sand
3. heavy compound with a cutting pad - low speed
4. med/light compound with a polishing pad - medium speed
5. polish with a finishing pad - high speed
6. apply wax or sealant by hand or orbital buffer
A picture would help.
Old 06-17-2003, 01:37 AM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
If you wetsand your car you going to have to clear coat it after.
Wetsanding takes all the clear of and makes the paint look dull.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 06-17-2003, 01:42 AM
Thats why wet sanding is not enough. Usually atleast 5 steps up to 7 or 8 steps with different levels of compounds & polishes. If you dont have have or have access to the chemicals & buffers, your better off taking it to a detail shop. All the supplies & equipment would run you nearly $300 or more to to this process properly.
Old 06-17-2003, 01:09 PM
how much would a detail shop charge about?
\m/ (-.-) \m/
Old 06-17-2003, 03:46 PM
$75-$150 depending on the damage
