Old 11-02-2013, 11:27 PM
bsr2002 bsr2002 is offline
Question p0240 code
So the only thing I have changed is the fuel pressure regulator. Man after I did that my cars been running super, even has some added pick me up on acceleration!
So today my check engine light comes on and I get this code????
p0240...
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 11-03-2013, 08:56 AM
Tech II Tech II is offline
Re: p0240 code
I think you have the wrong code.....sure it is not P0204? That has to do with the injector #4 circuit.....could be a bad injector, or the wiring harness to it.....see mice get under the upper plenum and eat the insulation on the injector harness......
Old 11-04-2013, 02:30 AM
Re: p0240 code
I'll have to wait till the check engine comes back on, I cleared it and am not sure now... sorry
Old 11-11-2013, 08:44 AM
Re: p0240 code
Okay, the code came back on today. P0420 looks like catalytic converter.
So, O'reillys or special order?
Old 11-11-2013, 12:05 PM
rkvons's Avatar
rkvons rkvons is offline
Re: p0240 code
I would go online and order one. How's the rest of the exhaust? If it is old, you can order the whole shabang for a couple hundred. It easier to replace than trying to splice in a new Cat to an old system.
The Following User Says Thank You to rkvons For This Useful Post:
bsr2002 (11-12-2013)
Old 11-12-2013, 02:44 PM
Re: p0240 code
I'll get underneath it this weekend and see, and start looking online!
Old 11-21-2013, 02:35 PM
Re: p0240 code
Well I bought a infrared temp gun at Home Depot yesterday for $32. I checked the front end of the Cat at 288F and the back at 450F! So I'm guessing the Cat is doing pretty good.
No leaks that I can see, so I'll wager it's the O2 sensor.
I was waiting till payday to get a Cat... well not no more it looks like.
Old 11-21-2013, 08:30 PM
Re: p0240 code
Not necessarily....that front temp is kind of low.....usually 350 or more....rule of thumb is 150F difference, front to rear.....however you can have an efficient running engine, and it can be less than 100F.....
Before I would think about that, I would do one of two things.....get a scan tool that can plot data, or get a scan tool and read before and after cat data.....
If you plot the data, and the image of the rear "mirrors" the image of the front, you have a bad cat......or look at the data of both sensors....the pre sensor should be rapidly changing low to hi and back, from 100mv to 800mv.....the data from the rear O2 sensor, should change very slow....if it changes rapidly like the pre, bad cat.....
Still could be cat......rich running engine could create a temp difference, and cat will not be running efficiently....
