Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-02-2013, 05:22 PM
thegreenhornet95 thegreenhornet95 is offline
Lose power when warm!!!!
1995 Suburban loses power when its warm and backfires through the throttle body when floored... Help please!!
Old 11-02-2013, 05:48 PM
j cAT j cAT is offline
Re: Lose power when warm!!!!
this can be a worn distributor bearing . remove cap check rotor for a wobble. if the rotor wobbles buy a new distributor.
THESE DISTRIBUTORS GO LIKE THIS 175k TO 225k MILES.
setting the timing is a little tricky.
Old 11-03-2013, 04:52 PM
Ok I installed a new cap and rotor. now i see the rotor rubbing against the cap
Old 11-04-2013, 09:43 AM
suburbanstevie's Avatar
suburbanstevie suburbanstevie is offline
Talking Re: Lose power when warm!!!!
I've had similar issue. It is not just the rotor and the cap. It is the whole distributor shaft, and the little bushing bearings on it. It sounds like a major issue to change, but it really isn't, and isn't too expensive either.
My bearings were worn pretty bad, causing the plugs to fire as much as 10 degrees off...randomly!
Let us know the progress. Good luck. And be careful, as with this change you will most likely feel a large increase in available power.
1990 Chevy Suburban, 454 cu-In, R2500
(always parked in the garage)
1999 Oldsmobile Intrigue, 3.5L
1998 Windstar, 3.0L
1984 Toyota Pick-Up, 22R
Old 11-04-2013, 12:39 PM
good now buy a new distributor ....make sure you follow the manual on install...or have a repair shop do it.
Old 11-08-2013, 09:05 AM
Thanks new distributor fixed everything!!! this truck haven't had this much power in years
Old 11-08-2013, 04:14 PM
thanks for your report ..good luck with the vehicle..
