Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 11-11-2001, 10:09 PM
G2002 G2002 is offline
Lightbulb Clear corners, side markers, and rear turn signals
Hey, I just ordered my 2002 black infiniti G20 sport and while at the dealer noticed that the turn signals on the G20 are made orange by a lil plastic cover they put inside the case at the factory. Does this mean I have to buy new lights to get the clear turn signal look or can I just take the lights apart and break that orange plastic cover? Has anyone done this that might know an easy way to go about it?:flash:
My car gets me from point A to point B, and every girl in-between :evillaugh
Old 11-12-2001, 01:15 AM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
take em off and get the orange out
Old 11-12-2001, 01:25 AM
wickedG20's Avatar
wickedG20 wickedG20 is offline
This is exactly what you need
Click Here
Old 11-12-2001, 03:57 AM
fuzzynaval's Avatar
fuzzynaval fuzzynaval is offline
I don't know if this works for g20's but worked for honda's...
we got a heat gun (pick it up at any home depot). And if you heat the glue around the egde of the lens and the assembly...you can just pull the plastic lens off. And the yank the orange out as a whole. And then you re-heat the glue...and stick the lens back on.
If the glue doesn't hold as well...just get some epoxy and and seal it.
Old 11-12-2001, 03:34 PM
Mrcoilover Mrcoilover is offline
Re: Clear corners, side markers, and rear turn signals
A lot of people tried it in here including me. It was kinda hard. Had to drill little holes in it and stuff but it reads easier than it really is. leave it like the way it is. Hard to do a clean job.
*Mod List*
2 JL audio W3 12's
Rocksford Fosgate 600w amp
Tein type NA (1.7)
Nokya Arctic purple headlight bulbs
Rims coming soon...
"I always ride dropped, how bout you?":finger4:
Old 11-12-2001, 06:14 PM
G20 SpoRt 2002's Avatar
G20 SpoRt 2002 G20 SpoRt 2002 is offline
Banned
Send a message via AIM to G20 SpoRt 2002
Thats the only way to get rid of the orange... Damn that sounds hard.. I guess ill try it..
Old 11-13-2001, 09:04 AM
Be sure to have a lot of patience. You'll need it.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-13-2001, 01:45 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
and make sure you dont drill all the way through the entire tail light. :alien2:
1.6 - The Underdog
GA16DE-T Club!
Old 11-13-2001, 03:38 PM
Yeah, can't forget that one.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-15-2001, 01:52 PM
AznVirus's Avatar
Re: Re: Clear corners, side markers, and rear turn signals
isnt it possible to just use a dremel and cut the whole thing off rather than drilling it into pieces and then using the dremel?
1.6 - The Underdog
GA16DE-T Club!
Old 11-15-2001, 02:06 PM
Nope, not possible. Its like trying to disassemble the center of a cube with one opening, and to get to that opening you put the dremmel down a narrow circular hole. Not easy.
l____l!
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-15-2001, 10:27 PM
Is it really that hard just to punch the orange cap out with a screw driver and break it up with some pliers and let it all slide out the hole?
Old 11-16-2001, 07:59 AM
Here is the deal. It took me 1 whole hour to do one. The orange plastic is a big cube with one opening, the one that lets the light bulb in. It has 2 points where it connects to the housing. The orange cube is bigger than the whole you are working with. The plastic is 100% made outa tuff sh*t. If you bang it with a screwdriver, you will knock the plastic loose in the housing and you can actually see it moving around and stuff. And then when you get the pliars, you have to pull hard as sh*t to get a little piece out. And when you use the pliars, there is a good chance of scraping the housing up. Hard to do a clean job. It is easier said than done.:huh:
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-22-2001, 03:25 PM
Chekmi21 Chekmi21 is offline
Send a message via AIM to Chekmi21
Yo trust me...mad difficult. I'm about to leave mine. I tried it but did not work at all. Try to heat the glue and take off the lens. The lens are held in there with two plastic clips (which can easily be pulled out I'm sure) and glue. Try your way. If it works...it'll be a hella lot easier than doing the old school dremel tool way.
Hard is an understatement...good luck anyways and let us know what the outcome is
2002 G20 w/sports package
Old 11-23-2001, 12:33 AM
wickedG20's Avatar
The smartest way to go is to get someone who has done it before to do it for you. Like if you ask an import shop, I bet ya they will do it for you. They have all of the necessary equipment to do a clean job. Sure you'll have to pay them a dub or two, but in the end it will all be worth it. peace
