Old 06-16-2003, 07:56 PM
fishrrprice fishrrprice is offline
1997 Escort Manufacture Code
Have a 1997 Ford Escort that the check engine light stays on, when I took it for emission ispection, they said the code was 1443, I then took it to an auto parts store, and they can't find any codes, they reset the light and it came back on the next day, does anyone know what the 1443 code is. thank you for any help. Gene
Old 06-23-2003, 10:54 AM
well if anyone is interested the problem was the gas cap, replaced it and reset light and no problems, Gene
Old 07-01-2003, 02:53 PM
Escort_LX Escort_LX is offline
What do you mean by the gas cap; is something on tyhe gas tank or on the engine(in which place).
If ain't broke dont fix it.
Old 07-05-2003, 03:49 PM
The gas cap itself, told the seal on it must have been broke, If you dont have a good seal the check engine light will come on. Gene
Old 06-08-2005, 04:57 PM
car dummy car dummy is offline
Re: 1997 Escort Manufacture Code
wow , the search button does work !!!! i,m also getting 1443, on a 97 escort , thanks
Old 06-17-2009, 06:07 PM
Dadcanfixit Dadcanfixit is offline
I had this code once before, a vacum leak could also cause this code, I traced all the vacum lines and found that the entire Charcoal canister filter for the gas fumes had fallen off the car.(located in front left fender area below headlight) I got one from a junk yard and replaced it and that solved my problem. Its been over a year or so but now I have the code back again. When I did the repair I also replaced two small black emmision elec valves located on the vacum lines coming from the canister. I will check the gas cap but if anyone else has suggestions feel free to chime in.
Old 06-18-2009, 04:59 AM
Davescort97 Davescort97 is offline
Escort guy
Per AF guidelines, please don't resurrect a thread that is over 3 months old. Instead, start a new thread.
