Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 10-31-2013, 09:32 AM
fuzzybaker fuzzybaker is offline
carb is running to lean
I have a 1986 toyota pu 22r carb it wont pass ca. smog they say its running to lean . What do I do?
Old 10-31-2013, 11:23 AM
rustydogy's Avatar
rustydogy rustydogy is offline
Re: carb is running to lean
assuming the vehicle is in otherwise good working order,,,,first check to make Shure all vacuum lines on carb/ intake manifold ,and where they connect to are good shape/ not cracked / broken /collapsed/replace if necessary , next make a heavy solution of dish soap and water/ spray around intake manifold and base of carb/ if this seems to make the engine run different you have a intake or base gasket leak /replace gaskets as necessary,,,,,,,,if all is good 1st check timing then find fuel/air mixture screw turn in until engine just starts to drop,,,,,,then turn out just till engine smooth's out then an extra 1/8 to 1/4 turn out you should be in the ball park/ also as a trick most states say you have to have a smog pump they don't say it has to work /if after doing as indicated you still don't pass take the smog belt off and try again/ if it still doesn't pass by just a little bit then go on a really nasty day/ Rainy weather ) will make it run richer
The Following User Says Thank You to rustydogy For This Useful Post:
fuzzybaker (11-02-2013)
Old 11-02-2013, 01:26 AM
thank you for the help, on my toyota pu. I only have 1 belt,but thanks for the information I will try tomorrow!
Old 11-04-2013, 12:45 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
You can also try putting some carb cleaner in the bowls and see if that cleans out the jets.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
