Old 10-30-2013, 09:34 PM
Randis Randis is offline
help 05 grand prix gt
Hi all need some help. Thought my transmission was slipping. So I changed the tanny.been driving it for a few days and now it doing the same thing. Is it possible that it a different problem with the same symptoms?
Old 10-30-2013, 10:36 PM
aleekat aleekat is offline
Re: help 05 grand prix gt
and the symptoms are?... so someone or you swapped out tranny with no diagnosis?
Post back, that's what makes Forums Work.
Old 10-31-2013, 05:57 AM
Symptom are slipping feeling. Yes I changed it my self. Brought it to a tranny shop they said tranny needed to be rebuilt. It was showing a code p1811.
Old 10-31-2013, 04:43 PM
Tech II Tech II is offline
So, you went to a tranny shop...did they road test the vehicle, or did they just read a code? What was the condition of the fluid?
What kind of tranny did you replace it with? Junkyard? Rebuilt? New?
Lack of diagnosis hear, may have cost you more than it should have.....
Normal fix for this code, is a pressure control solenoid....in some cases the valve body also.....if driven too long like this, than clutches could have been worn....
If you replaced it with a junkyard tranny, since this is a common code, you may have replaced it with a tranny with the same problem....
Now for the bad news....it could have just been a wiring problem in the harness to the tranny......
Proper diagnosis, would have been for the transmission shop to road test the vehicle with a scan tool and look for slippage, especially under a load....if slippage exceeded 30-40 rpms, than the pressure control solenoid should have been commanded to 100 %....if slippage was gone, chances are you just needed a pressure control solenoid.....while in there, the valve body should have been checked.....
Old 11-03-2013, 07:27 PM
I'm not sure if they took it for a test drive. It was not me who took it to the shop. I think I'm just being paranoid. Thx for the help.
