Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-28-2013, 12:52 PM
kenc195 kenc195 is offline
ignition key wont engage
I put the key in and maybe 1 out of 10 times it wont turn to start the engine. When I pull it out and put it back in 2-3 times it will turn. I tried my spare key and it still happens. I have W2-40'd it with no help. I am out in the wilderness a lot and don't want to get stranded. is it the switch or has the interlock cable shown this as a problem? What are the steps to replace the switch?
Life is good with my 97 Passport
Old 10-28-2013, 10:09 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: ignition key wont engage
peak your head under the steering wheel.... there is a cable that runs up the ignition. push it around a bit and it may help. Also there is is a small screw that is connects the cable to the ignition that sometimes comes loose.
to tighten the screw you need to remove the lower plastic cover ...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
