Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-27-2013, 02:48 PM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
gear ratio?
Can the gear ratio be determined from the VIN? Maybe using that to get a build sheet? Looking at a used 2003 Suburban from a dealer. It has the towing package but tow capacity is based on gear ratio, 3.73 or 4.10. Wanting to tow a 35' travel trailer just over 8000#.
3GNEC16Z33G154346
Thanks for any help,
Rob
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 10-27-2013, 05:22 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: gear ratio?
That one came from the factory with the 3.73 set up.
Old 10-27-2013, 06:37 PM
rob67gmc's Avatar
Re: gear ratio?
Thanks, that's what I needed to know.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 10-27-2013, 07:03 PM
j cAT j cAT is offline
Re: gear ratio?
the glove box should have all the numbers to determine what the vehicle has as built.
these codes will tell you just about everything specific to your vehicle.... the dealership can with the vin# look up this info if the label has been destroyed. if the label has been removed get a vehicle history report ! be safe !
Old 10-28-2013, 09:16 AM
rob67gmc's Avatar
Re: gear ratio?
Thanks.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 10-28-2013, 10:21 AM
gmtech1's Avatar
Re: gear ratio?
All true. I used your VIN to pull the RPO codes. You have RPO GT4 (3.73 ratio) and G80 (locking rear diff). I can also tell you the delivering dealer was Winner Chevrolet Inc. in Ayden N.C.
