Old 10-27-2013, 01:24 PM
mikeso_81 mikeso_81 is offline
High Idle/Stuck Accelator after Fuel Filter Change
Hi,
I just changed my fuel filter and now I am having issues with the idle/accelator. When I get the car going to a speed of 40mph for example, I let off the gas and the speed barely drops. Then when I went down a side street about 20 mph, I let off the gas and the car just kept going. The idle was initally high, but then dropped down to it's normal 800rpm.
The only thing I touched under the hood was releasing the pressure from the fuel pressure regulator before the fuel filter change. I just removed the idle control unit and cleaned it but that didn't help.
Thoughts?
2001 Pontiac Grand Prix GT/3.8L
Old 10-27-2013, 09:10 PM
Tech II Tech II is offline
Re: High Idle/Stuck Accelator after Fuel Filter Change
Several possibilities....
Vac leak.....
Sticking throttle plate or throttle cable....
Bad IAC valve....
Any codes set?
Old 10-29-2013, 02:44 PM
The check engine has't come on, but I'm going to borrow a scanner from a friend and check for a vaccum leak this weekend. I ordered a IAC just in case. Let's see if any of that helps. I'll reply once I try these things out.
