| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
h22 swap
im about to do an h22 swap into my 4th gen accord. The guy im buying it from said that the f22 tranny will work okay but the gears will grind when shifting at high rpm's. Thats the first i heard of that, is it true for every swap? Also is there any difference in a JDM h22a from 92 and one from 93? thanks for your help
ummm let me ask something real quick... isnt the h22a motor a prelude motor?.... if it is which i think it is.... i know the 93 preludes were the first year for the vtec so there might be a differance
"The Storm is COMING" |
the 92's in japan also got the h22. it is the same. the gears shouldn't grind.
www.cb7tuner.com |
im guessing the grinding in the gears is because the f22 tranny wasnt built as strong as an h22 tranny? i could be completely wrong...but it kinda makes sense with the power difference. kinda.
96 Accord EX 5spd coupe - black --- AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter --- pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES |
i have the h22 on my accord and is a easy swap on a 4th gen accord and yes you can put the f22 tranny but is not worth it you should get the h22 tranny if you want the real power of the h22.................if you are doing the swap and need help just PM me and i can tell you everything you need its a real easy swap.......
Tranny only grinds if its bad. It has nothing to do with what that guy told you. Most ppl think that u can't use the f22 trans with h22 cause f and h dont mix but it does. F22 is good for turbo though if your gonna go that route keep the trans.
Go to this site for more info. www.h22a.org |
how much power would i really be losing if i stuck with the f22 tranny?
also does anyone know if haynes makes a manual for the prelude? i couldnt find any |
no more than with an h22 tranny it just has longer gearing so you wont accelerate as fast (n/a) and just get the helms. its worth it.
www.cb7tuner.com |
its not a significant loss in acceleration, is it? i mean like half a second is okay. but not longer, right?
anyone know anything about swapping a OBD II H22 motor into a 93 accord? lend me a hand yals, thanks... i need wiring help... i got a helms, manual, but then some plugs are different from the others and wont plug. so i re-wired them to make it fit, but there are still some missing connectors to connect to the motor... also i have another question, can i just use the OBD II H22 engine wiring harness and use the H22 chasis harness and just connect that to my car. and can i just use that H22 chasis harness and plug it to the ECU onlt, and leave the other plugs unplugged...
Im puttin an h22 into my f22 but keeping the tranny , its an automatic, but im not going to change the tranny right now, I was wondering if anyone could email me to send me details on the wiring or in depth instructions atleast something, i just need some help. how well would my f22 tranny hold up, also have zex wet nitrous, will tranny be ok with h22 and 55 shot?
