Old 06-12-2003, 10:07 PM
h2ofreak h2ofreak is offline
Question 94 problems
my sister just moved in w/ us. she has a 94 gp. There are several issues which make me sad to see. I was wodering if someone could help me help the poor girl out. (by importance of safety).
1)the turning signals do not work-- always. the left not at all, and right every other day. checked fuse, could not find the flasher (I don't think that is it), might it be in the column?
2)driver door opens only sometimes I think its the latch not releasing-charming to see her crawl in the passanger side on its "bad days"
3)ocasional stall. Her mechanic back home says he fixed it ($350.00), but it started up again. Since, I tightened the battery cables. seems to have stopped. Any help is appreciated!!
Thanks in advance.
PT
Old 06-12-2003, 10:53 PM
scrubin63125 scrubin63125 is offline
My suggestion...Buy a new car.
Old 06-13-2003, 01:20 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
C'mon scrubs, be a little more positive!
The door latch mechanism probably needs to be replaced, and there should be a fuse for the turn signals, check the owners manual for other fusebox locations.
Old 06-16-2003, 02:25 PM
Thanks for the suggestions guys. I cant imagine how many times I've suggested a new car. (besides a financial issue for her), I would like to see it repaired so that the next guy has better luck. As for the signals, checked the fuse I'll keep searching
thanks
Old 06-16-2003, 03:46 PM
also look under the dash to the left of the steering coumn I believe there is a relay under there they are roughly $20 and if it is bad it would be doing what you are saying. That location is not exact but it is under there somewhere maybe ask a knowledgeable person at the local auto parts store where it is.
Old 02-13-2004, 08:07 PM
wishmaster10 wishmaster10 is offline
Re: 94 problems
Hi I had the same problem with the singal lights in mine and is was the switch under the sterring columm check that it might help you
Kevin
