Old 06-12-2003, 03:52 PM
91BLKsi 91BLKsi is offline
Send a message via AIM to 91BLKsi
Question acura ls throttle body
Anyways i have a 93 acura integra throttle body. What would happen if i put it on? Will i get more power or what?
Old 06-12-2003, 03:57 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
will it even go on? I was under the impresson that B series parts werent compatible with D series parts.
Most likely your car would run worse though, because that throttle body is optimized for a bigger engine.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-12-2003, 04:00 PM
Oh..Anymore thoughts on this..Because..i wanna put it on rite now
Old 06-12-2003, 04:10 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
actually, i believe you would get a boost in porformance, considering its a larger (in diamiter) throttle body
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 06-12-2003, 04:12 PM
Melt's Avatar
yeah but if youre on stock internals your car wont be able to make use of it ... Just like if you were put a 3" pipe all the way back on our civics they lose power.
AF Bay Area Crew
OK..thanks..More more???...Civic dude where are you??...Need YOUR opinion
Old 06-12-2003, 08:51 PM
Melt's Avatar
I asked about this on another forum and it WILL fit ... but we are still busy arguing about if there would be a gain or not.
AF Bay Area Crew
Old 06-12-2003, 11:42 PM
91civicDXdude's Avatar
B series throttle bodies wont fit on an A6 manifold, but they will fit on anything after A6 like a Z6. but i repeat... will not fit on A6 manifold.
Old 06-13-2003, 12:09 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
survey says.......brrrrrrrr
The throttle body WILL fit on a a6 Si manifold, but it has to be from a 90-91 Integra. 90-91 is Obd-Zero, 92-93 is Obd-1
It will give you more power, but it won't be usable since it will be way up high in the Rpm band. Also, it will take away low end, so unless your motor is worked, it will do more harm to the meaty part of the power band than good.
There's nary an animal alive that can outrun a greased Scotsman!
Old 06-13-2003, 12:22 AM
Rufes1's Avatar
Rufes1 Rufes1 is offline
Send a message via ICQ to Rufes1
yeah i wouldnt bother man. like he said unless your motor is worked you wont really benefit from it.
Old 06-13-2003, 01:54 AM
I have an OBD2 throttle body on my OBD1 manifold with an OBD0 ECU
Old 06-13-2003, 03:32 AM
Alright then, I stand corrected....
.....smart ass...hehehe....
Old 06-23-2003, 10:14 PM
Any ways i put the the ls throttle body on..My car was idleing(sounded sweet)...Then all of a sudden tht car started to high rev by itself!!..Like it was crazy or some shit..Anyways i took it off
Old 06-23-2003, 10:22 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
air flow sensors probably got all confused by the different volume of air.
