Old 06-12-2003, 01:41 AM
CRX586's Avatar
CRX586 CRX586 is offline
steering problem
i'm not sure what the problem with my car is... the steering feels loose and shakes back and forth even at low speeds. its not the allignment. someone told me it might be the rack... any ideas?
02 Lexus IS300
Old 06-12-2003, 01:49 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Check your wheel bearings and ball joints to see if they're good or not.
Old 06-12-2003, 03:47 AM
CRX586's Avatar
thanks... i'm guessing this isn't too costly and/or labor intensive?
02 Lexus IS300
Old 06-12-2003, 03:54 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
Put the front of the car up on jack stands.
Grab each side of the tire, and try to rock it side to side quickly. If your stuff is tight, it wont move. If its loose, then its what mellowboy said.
I had a bent rack in my car before, similar feeling. Your tie rods or tie rod ends may be bent also.
good luck
There's nary an animal alive that can outrun a greased Scotsman!
