Old 06-11-2003, 10:40 PM
doug294 doug294 is offline
Send a message via AIM to doug294
How to tell if my O2 sensor is bad?
How do I know if my O2 sensor is bad?
Old 06-11-2003, 10:52 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
generally the check engine light would come on and your ECU would throw a code
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-11-2003, 10:55 PM
my check engine light is one, but I don't know how to read the codes. Plus it doesn't stay on, it comes on after a few min, will it through the code when it comes on?
Old 06-11-2003, 11:10 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Just replace it anyway. O2 sensor should only be like 15-20 bucks. If thats not the problem then you still have a new O2 sensor that will last you years to come
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 06-11-2003, 11:34 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Usually your car will run very rich (you will get shitty gas mileage).
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-12-2003, 10:58 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
To see error codes, pull back the passangerside carpet, you should be able to pull it far enough without taking anything off/out. You should be able to see a small circle. It will have a red LED that will bink when the key is turned to ON. The ECU's have a memory so the engine light doesnt have to be on. The light will blink rapidly to represent the code. If there are more than one codes, it will blink the one, then pause, then blink the other.
One blink means O2 sensor
