Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 10-23-2013, 03:31 PM
tp1260 tp1260 is offline
1995 Beretta turns over but won't start
The last few days the car would run fine, at first. If i had to shut if off for a few minutes, and then restart it, the car would not idle right.
Today, it was a totally different situation.
It started for a second , then stalled, i turned it over again, it started right up.
I revved the engine a little, and the car just died.
It will turn over, but it won't start.
After running the battery down to nothing, i used a jumper, and again, turns over fine, just will not start.
I have been noticing over the last few months i would check the gas cap, and it would be loose, but that would never stop it from running.
Does anyone have any suggestions on what the
problem may be?, or what i can check?.
Thank you for your time.
Old 10-23-2013, 06:05 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 Beretta turns over but won't start
Do you have fuel pressure at the rail, strong spark to the plugs, all basic diagnostics.
