Old 06-11-2003, 08:45 PM
crx hf crx hf is offline
starting problem
Well when ever i start my rex it takes me about 3 0r 4 times to start it.It turns on sputters and then quickly dies.It gets worse every week.What could it be?Could i be i need a new starter?Also it idles really low like 2 lines under 1k RPM.
Old 06-11-2003, 09:23 PM
chopstick1981 chopstick1981 is offline
couple lines under 1k??? do you mean 800, cuz thats about where mine idles and it runs fine. when you say "spudders", do you mean it turns over but doesn't start or it starts and then dies. Be a little more specific
Old 06-11-2003, 09:41 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Yeah min did that. Like you start it and it turns over but won't start. Then you get it started and the its like put put put and quits. Mine did that too. Now for some reason it won't start at all. Sounds like we are having the same problem.
Old 06-11-2003, 10:40 PM
IT starts but then it dies.It still runs but it takes me a couple of times to get it running.
Old 06-11-2003, 10:42 PM
Do you guys know what it is?
Old 06-11-2003, 10:53 PM
No, mine started doing that, then the other day it just wouldn't start at all.
Old 06-11-2003, 11:16 PM
Im thinking it could be one of 3 things:COIL,main relay or starter.I just dont know where the main relay is.If you fix your car DOUG le me know what i was.
