Old 10-22-2013, 07:06 PM
HeWhoKillz HeWhoKillz is offline
flushing the cooling system
What tools do people use to flush the cooling system? I'm doing this on a 94 caravan but I doubt that will matter.
Old 10-23-2013, 07:41 AM
vgames33 vgames33 is offline
Re: flushing the cooling system
Shops use a machine that forces pressurized coolant in and collects the old as its pushed out.
If this is just a maintenance thing, pull the lower radiator hose and drain out what you can before refilling. I use compressed air through the radiator cap to get a little extra out.
If you have a blocked cooling system, there are many flush chemicals out there but you'll have to do a more complete drain.
Old 10-23-2013, 05:15 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
A garden hose.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-25-2013, 07:07 PM
Well, I have barely any heat in this van. There is "more" heat when its driving or revving. At a stop, it gets much cooler. Both of the hoses going into the firewall are hot. Flushing it didn't help. So I'm not for certain it is a heater core.
Old 10-26-2013, 10:19 AM
Could be the water pump or low coolant/air pockets.
Did you flush the core itself? Since you can access the lines to it, shove the garden hose in there and pump water through it.
Old 10-26-2013, 05:55 PM
Wouldn't the car overheat? I'm not experiencing that.
Old 10-27-2013, 12:50 PM
You should see overheating with a worn pump or low coolant level, but if the pump is marginal (fins rusted away, but not completely gone), you may get weak heat at idle without noticeable overheating. The water pump is the last part I'd check due to the work involved. Pump failure is common on the 3.3/3.8 engines.
Try flushing the core directly and see what happens. You should be able to tell if its clogged by watching how easily water flows through it.
Old 10-27-2013, 08:08 PM
Toolaa Toolaa is offline
This sounds like an air bubble trapped in the system. I'm not 100% sure but many minivans have the heater core above the highest point of the engine. So any air in the system will eventually find it's way to the heighest point. When the engine is running at idle there is not enough water pressure to flow past the bubble. However when the engine is running faster the pump pressure is able to overcome some of the bubble and some hot water does circulate through the core.
There is a tool you can buy called the Airlift 550000. Or search for other models of "Coolant Vaccum Refill" tool. There are videos of how to use them on you tube too.
