Old 06-11-2003, 07:22 PM
ryanryan ryanryan is offline
90 civic with poor combustion engine
condition : engine with 350000 kms and internal engine damage maybe caused by bad valves, and compression rings.
trying to maintain idle by turning the idle screw above normal 800 rpm
caused a surging engine
the following is what i have gather or assumption
ECU will cut fuel to injector in order to conserve gas when rpm is above normal with thottle posiiiton closed . example when vehicle is slowing down
ECU will open injector once rpm is under normal 800 rpm thus causing the surge
rpm is determine by distributor signal
how can i maintain high idle without surging ?
the only time that i do not see a surge in rpm is when engine fan on
Old 06-11-2003, 11:55 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
You should have you valves checked out along with your rings. Your valves could have mushroomed tops, or even warped face.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 06-11-2003, 11:59 PM
Tanked Tanked is offline
Some idiot mechanic that worked on my car set my idle at 1200 RPM and it was fine, except that it was wasting fuel.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
