Old 10-22-2013, 10:52 AM
Brian Cameron Brian Cameron is offline
Escort spark trouble
I'm so darned old that I still know how to work on 50's type engines but I get a little confused on newer stuff. My kid's escort has a spark issue (no spark),and I'm trying to remember how to test the coil. But I see references to the coil pack or coil module and also references to the TFI module.
What 's the difference between the coil module and the TFI or ignition control module?
I read that one or both of them are the typical problem on escorts when it comes to spark trouble.
Should I have him just replace both?
I'm trying to diagnose this via email since my kid is 200 miles away.
Thanks
Old 10-22-2013, 06:30 PM
Re: Escort spark trouble
well I got no replies but in the meantime I found out some more info. I see now that this escort (a 1.9) just has a coil module and a distributor. I also see that it has some sort of fuel injection system I'm not familiar with . There is an electronically timed spay inside the air cleaner and an intake manifold rather than 4 separate injectors.
There is spark to the distributor and spark to each plug. There is fuel mix spray at the top of the intake manifold but engine won't start.
This thing was running fine until 2 days ago .It started right up and then died.
Any ideas??
Old 10-30-2013, 05:48 PM
rhandwor rhandwor is offline
Any ideas??
If you have spark and fuel you could have a plugged air cleaner. Check if your timing belt is loose or broke a tooth.
The Following User Says Thank You to rhandwor For This Useful Post:
Brian Cameron (10-31-2013)
Old 10-30-2013, 07:08 PM
rustydogy's Avatar
rustydogy rustydogy is offline
ok I will take your word for it , it has spark and fuel the only thing that's missing as air and TIMING.............even if air cleaner was plugged it would still fire up for a moment but those little motors have timing belts and do have a way of skipping time enough when you shut down and the engine,,,,,,,,,,( diesels or kikes back )we know the belt is still on because the dist. is located on the end of the cam ........bring it up to top dead center and check your marks on crank to where they should be on dist. then get a new timing belt and reinstall it id bet your over 60.000 and its never been done
The Following User Says Thank You to rustydogy For This Useful Post:
Old 10-31-2013, 10:47 AM
Thanks to both of you. We determined it is the timing belt. Even though it is still on it turns out it is pretty worn and lose. So we're putting a new one on. They couldn't have emade it any more difficult to change the belt on those escorts!!! Having to drop the engine to remove the lower pully just to see the dang timing mark!
Old 10-31-2013, 11:52 AM
rustydogy's Avatar
oh no I hope you didn't take it all the way out just un do the mount at belt side of motor and remove tire, gives enough room to remove and replace the belt/ replace the tensioner too
Old 10-31-2013, 01:44 PM
rustydogy- I'm at a disadvantage since I can't see the car.It's 200 miles away in my son's driveway. All I can go by are pictures I looked at on the internet and what my kid tells me. He says he took off the passengerside wheel and there is a small hole large enough to get a socket on the pulley but no room to pull the pulley. I told him to try dropping that side of the engine by disengaging the motor mount at top front of engine..
A lot of trouble just to see the timing mark for the crankshaft I thought but he says there is no way to see the mark with the pulley in place and the engine mounted.. Please tell me if there is abetter way.
Old 10-31-2013, 03:02 PM
aleekat aleekat is offline
sounds alot like the mazda 626. There is an inside rubber splash cover in the wheel well you have to remove. I'm not sure if the escort is an "interference" motor. So he has to be absolutely sure he has everything aligned correctly before he attempts a start. Someone will probably answer this.
Edit: Take alook at autozone their online repair guides. The do cover alot. Signup is free..
Post back, that's what makes Forums Work.
Old 10-31-2013, 03:32 PM
he didn't mention any removable cover. That would sure make it easy. As far as interference engines go... I was worried, too, that he could have bent a valve while trying to start the engine when he didn't know what was wrong. I would think that since the time manufacturers began using timing belts instead of the sturdy old timing chain, that they would take into account that as soon as a belt slips or breaks, the driver is going to crank over the engine again and again so it would be stupid to make an interference stye engine with a timing BELT. But at this point we just have to press ahead and get it timed and hope for the best.
Old 10-31-2013, 03:49 PM
rustydogy's Avatar
http://www.youtube.com/watch?v=XxC3EAVfWwA it is not an interference engine some 4 bangers are, but not this 1 ,and if I got year wrong all ford1.9s are same timing belt and tensioner if you can send this on to him to help just copy and past in e-mail or you watch and then after seeing you can explain it easer he will need a jack to rais and lower the belt side of motor
Old 10-31-2013, 04:32 PM
Good video. Thanks.He should be able to lower the belt side of engine since he and i dropped it just a few months ago to replace the clutch (stupid transverse mounted engine with no working room!). I couldn't find any video to show just how that belt tensioner can be relieved to get the new belt on. In the video you sent I see the guy pulling on a socket wrench attached to the tensioner, but I didn't see that it actually did anything.
Old 10-31-2013, 05:11 PM
rustydogy's Avatar
thCAP8B7Q4.jpgafter he gets it on and sets tensioner snug it down rotate motor 1 complete cycle 2 crank turns /clock wise / check to see if marks line up right/ if they do then loosen tensioner and jus lightly tap it for final adjustment, let it move with its own spring pressure then retighten tensioner , put all back together
Old 11-01-2013, 09:33 AM
he didn't mention any removable cover. That would sure make it easy. .
Glanced at the vids rustydogy posted. Vid 2 shows the removable splash cover I was talking about.
Old 11-01-2013, 09:53 AM
Thanks guys- I sent that image of the waterpump/tensioner on to the kid. He says there is no bolt on the front of the tensioner. And says there is no removable section in the wheel well. His escort is a 1990 so who knows? It is definitely different than the 93 and in fact is NOT fuel injected either.
At this point ,he has dropped the belt end of the engine and is ready to pull off the crank pulley. Thanks for helping us out on this!
Old 11-01-2013, 10:29 AM
http://www.autozone.com/autozone/rep...00c1528008b335
You may have to sign up. autozone repair guide with pics.
